Kyser
- 124
- Dec 11, 2001
Milwaukee,
Wisconsin
After replacing the power steering rack my car does not want to go forward. We just finished replacing the power steering rack in my car and when we went to move it, the car basically bogged alot. If you just gradually release the clutch the car rolls forward fine but when you give it gas it feels like your trying to tow a semi behind you. Reverse seems perfectly fine, just releaseing the clutch and when giving it gas in reverse everything seems perfect its just trying to go forward doesnt seem to be happening. Only thing thats not on the car atm is the sway bar links, but we dont think thats the problem. Made sure the sway bar wasnt getting in the way of anything so now we are kinda thrown for a loop. If anyone has ideas please help cause I would really like to drive my car eventually.
~Lyle
~Lyle
. As he stated the 5th gear nut has a tendency to fall off and bog things down in the tranny then blow the case apart...hopefull that is your problem:
