Keep Blowing MPI Fuse After S-AFC Install
scottr126
366
2
May 24, 2003
CHICAGO, Illinois
I just finished installing my afc so I went to go start the car and the car just cranked and didnt want to start so I began checkin fuses and I noticed that the MPI fuse that hangs off the battery was popped so I replaced it and went to go start the car again and sure enough right when I move the key the fuse just popped. It does this everytime I try to start it so i disconnected the big fuel injection relay thats down by the ECU and sure enough the fuse didnt pop but obviosly the car doesnt start without it, what could it be thats causing the fuse to pop??
I found the problem, one of the wires that goes to my fuel relay got stripped and was rubbing on a ground. its all good now.
