1.8
And which head is the one that is used on the 2.0 that increases compression since combustion chamber is smaller.?
The 1.8 and 2.0 are completely different motors. The 2.0 (4g63) uses a dual cam head, while the 1.8 (4g37) uses a single cam head. The heads are not interchangeable between motors.
The 4G61T head I believe has a slightly smaller chamber. But these days, it's easier to just throw higher compression pistons in to get any CR you want rather than searching for old worn out heads.
