Closing Shop, Selling Everything
RvlutionMtrsprt
719
26
Jan 15, 2005
Eugene, Oregon
I have decided to call it quits for good and move on with my life. I enrolled in school, which starts in September and I'd like to have as much cleared out by the end of the summer as possible.
I'll try to make a complete list after the 4th. Needless to say, there's a lot of stuff here that needs to find new homes!
Sorry to hear that.
Let me be the first vulture to say I'm looking forward to a list.
Well here's the first list:
OEM PARTS:
1G T-Case recall kit $10
MD156604 T-Belt Idler pulley $35
MD340327 T-Body Gasket $2
MD020260 Head-Block dowel pins $2ea
MD050317 Oil Drain crush washer $1ea
MD149370 OFH Gasket $2
MD343563 Front Main Seal $15
MR258477 Oil Return Gaskets for 14b/16g $1ea
MR312761 BOV Gasket $2
MD191502 Timing cover Gasket $1.50
MD189460 14b/16g turbo outlet gasket $2.50ea
MD198888 Turbo oil return gasket for t25 $1ea
MD372536 cam seals $10ea
MB928459 GVR4/1G brake master cylinder rebuild kit $70
MF101229 turbo oil return line bolts $1ea
MB153825 GVR4 front grill clips $1ea
OEM water cooled oil cooler gasket $5 (big orange o-ring between OFH and cooler)
MD377604 2g harmonic dampener $135
MD730979 Reverse light switch, new, $15
AFTERMARKET PARTS:
FP turbo to manifold gasket $15
HKS 272 Exhaust Cam <4,000 miles use, $200
HKS 40mm external wastegate $200
StopTech Rear Rotors 2G AWD slotted/coated $160 (cost $190 new from RRE)
Wiseco Pistons K548M855 (missing rings) $300
1G DSMLink V2.5 new $275
SX Fuel Filters #41002 $75ea
HKS turbo timer harness for 1G, new, $15
Greddy Profec B EBC $225
Bosch o2 sensor for 2G AWD rear, new, $60
Sparco Steering Wheel, new, $200 suede and leather, horn buttons/nitrous on wheel
AeroTurbine 4040L Muffler $160
HKS T4 Exhaust Manifolds x2 $700ea
HKS 50mm Race Wastegate $275 ($590 new)
Garrett GT4202, new, 1.15 divided T6, $900
Holset HX52 Pro, billet wheel, 16cm divided "T4", machined to fit T4, $900
ETS cold side intercooler pipes, mild/black, hks bov flange, stock tb, $75
Momo/SSR Superlight Wheels 16x8, new, cosmetic damage to finish, $600
ACL Race Bearings, coated from MAP, $150
2G Non-Eprom ECU's $50ea
HKS bov o-ring and clip, new, $20
FIC injector o-rings, new, $20/set
1G BOV adapter for 2g/evo, made by ETS, used, $10
JMF DIY Flanges, divided T3 $45, divided T4 $45, Evo 8/9 $50, all ss, all new
3x ABEC shift cable bushings $5/pair
Easiest way to get a hold of me is to call the shop @ 541.505.8567
I accept cash/paypal/postal MO's. Call or PM me if you have any questions or would like any pictures.
Thanks,
Jesse
It has a clean Oregon title, I haven't found any rust on it, it's pretty well stripped out... no engine/trans/ecu/ecu harness, engine bay harness. Green exterior, grey leather passenger seat, black leather rear seats. 5 speed, 4 bolt lsd rear end and axles still on the car (and I want more than $200 if that stays). Has 3 OZ edition wheels, 1 maxima wheel. I'd take $400 for the chassis with 4 bolt and axles. Any other questions call me at 541.505.8567 and I'll answer them.
I've got a line on a pretty clean '97 GSX chassis that I might pick up and part out. There's a dent on the rear passenger quarter and a small dent (from inside out???) on the drivers door. Otherwise, the tan leather interior is all there and very clean. Aprox 115k on the chassis, 5 speed, 4 bolt LSD rear, good trans, blown motor (50,0,0,25 compression).
And Jon is right, there's still a crapload of parts laying around the shop that need to find new homes before they find the scrap metal pile.
Im very interested in the 1g recall kit is it the yoke ujoint and seal pm me details
How much do you want for the GSX?
How much do you want for it? you can take all the interior, except the console! LOL I need a black one!
Edited List:
Need to clear quite a bit out still.... Call/text if you have any questions 541.337.4792
OEM PARTS:
AFTERMARKET PARTS:
