my ECU
debow_8787
186
Aug 20, 2007
buckley, Washington
i think my ECU is ####ed it still work but it is hard to start when it is cold it takes like 5 to 10 trys to get it started the when i get it started it idles at 1500 and when i rev it up it will go down to 2000 and sit there for a sec then drop back down to 1500 and when the car is worm and i take it to 5000 it will act like it is getting fuels cut.here is a pic of my ECU the burn is not on the other side can any one fix it of dose any one have a 90 ECU?
<a href="http://s307.photobucket.com/albums/nn288/McLovin8787/?action=view&current=Picture002.jpg" target="_blank"><img src="http://i307.photobucket.com/albums/nn288/McLovin8787/Picture002.jpg" border="0" alt="Photobucket"></a>
looks like the surface mount capasitor is burn,t out .you should just find the value on that part and replace it . I have one with it replaced, I will check it out when I get home from work .I will let you know what can work in there .
looks like more then just a cap. like stated i would send it in.
i might have a similar issue with my split second unit and i have similar motor issues.
mine is running super rich and it might have blown the motor. so i would stop running the car to prevent any further damage.
thanks for all the info i have to wait tell i get some money coming in i mite just get a new ECU i dont no yet i need to get my lower ball joint fixed and i really need a set of wheels and tires so if any one has a set and would like to trade somthing for them hit me up i dont care if thay are stocks or not.
I have an extra 91 AWD Federal ECU. If you are interested PM me.
