Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > Community > Regional DSM Clubs > Pacific Northwest DSM Forum
Pacific Northwest DSM Forum Washington, Oregon, Idaho, Alaska, etc.
Pacific Northwest Region Homepage
Reply
LinkBack Thread Tools
Old 05-07-2008, 01:24 PM   #1 (permalink)
Proven Member
SonySlave's Avatar
Region: Pacific Northwest
Classifieds Rating: (0)
Reputation: SonySlave is pretty helpful and trustworthy
Leakdown Tester
So I broke something at the track last Saturday. The car was running great all day long. The car ran a best to date 12.2@114 and 12.2@117 (thanks to Brummellz). I was ecstatic! Then on my last run, during the 3-4 shift, the car started shuttering really bad. The motor was missing really badly. My friend Lucas was thinking I burned another valve just like I did last summer. So I packed up and drove it home.
I pulled the plugs first to check them. Plugs 2-4 were all intact and dry with regular carbon buildup on them and no peppering. Plug 1 was also intact, but had oil on the lower half of the threads near the electrode. Also, oil had kind of seeped out from cyl. 1 between the head and exhaust manifold. I looked onto the piston tops and #1 was wet. I also pulled the exhaust manifold off and there was oil around the #1 port area.
So I did a compression test. It was a cold test, which I know reads lower, but better than nothing. Cylinder 2 had 125psi cold, cylinder 3 had 130psi cold, cylinder 4 had 75psi cold, and cylinder 1 had 10psi cold. So I added a capful of oil to #4 and it jumped to 135psi. Added a capful to #1 and it made no difference at all. Still 10psi.
I'm a little confused about the 10psi compression. Last year when I burned a valve, there was 0 compression, I mean NONE! But now the gauge definitely jumps right to 10psi. So I'm starting to wonder about things. The head was rebuilt last summer because of a burnt valve, but the bottom end has 138k original miles on it. I really wouldn't be surprised if something in the bottom end is bad, possibly the rings, due to the oil coming out of the #1 runner. However, the car doesn't smoke at all. I don't know...
So basically after all of that, I need a leakdown tester to see where the problem is located... Does anyone have one that I can borrow for a day for a 6-pack?
Online
Related Auctions
Sponsored Links
Old 05-07-2008, 01:40 PM   #2 (permalink)
Banned
Region: Central Canada
Classifieds Rating: (5)
Reputation: droppinbottom is pretty helpful and trustworthy
Wish I could help you but I don't have a tester either.
Just my .o2 but it does sound like #1's rings are gone causing blow by or the oil is coming down from the head.
Wish ya the best of luck. If it is a burnt valve I wonder what is causing you to keep burning valves.
Offline
[posts] Reply With Quote
Old 05-07-2008, 01:57 PM   #3 (permalink)
Proven Member
Region: Midwest
Reputation: Boost92awd is pretty helpful and trustworthy
Hey if worst comes to worst you could always buy one. Check ebay you can get one from like $30-$50. It would still be cheaper than taking it to a shop and having them do the test.
Offline
Old 05-07-2008, 02:51 PM   #4 (permalink)
Proven Member
Icarus's Avatar
Reputation: Icarus is an unknown
Sorry to hear about that man, it sound like either way you may have some down time ahead Wish I had a leakdown setup. Well I hope it's something cheap and easy, good luck.
Offline
Old 05-07-2008, 03:13 PM   #5 (permalink)
Proven Member
Region: Midwest
Classifieds Rating: (4)
Reputation: Laysher91 is more helpful than not
I found this tester and was going to purchase it but at the moment none of my dsms are running . So I have no need for it yet. But for the price I think its worth having around
Harbor Freight Tools - Quality Tools at the Lowest Prices
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Did a leakdown test and...... lowandsleekDSM Newbie Forum 5 02-26-2008 04:38 PM
Exhaust Leak Tester?! Loosing boost and loud humming... need a leak tester samnumba1 Newbie Forum 11 05-19-2005 07:12 PM
Buying Leakdown tester is 4g63 14mm or 18mm plugs? [14mm] n0va91TSI Newbie Forum 1 10-17-2004 02:53 AM
Leakdown Tester Question alwaysworking Problem Diagnosis 5 10-31-2002 08:14 PM
Page generated in 0.14233708 seconds (75.71% PHP - 24.29% MySQL) with 10 queries
