vac lines
trevnasty
249
Feb 27, 2008
kalispell, Montana
ok the need to now witch vac lines i put on i took them of with out marking them they are the one that plug in to the intake manifold right next to the throttle body i have a all black one,black with red dash strip,black with blue or green dash strip,black with yellow dash strip.
wasent thinking when i took it all part:nono:
i dont really understand it all i need is a pic of a stock engine bay set up or someone that can tell me what strip color go to what vac tube
OK , if your standing at your passenger wheel looking at the 4 nipples on the throttle body it goes like this .... left to right.....black/black (perge control valve top).....black/yellow (thermal vacuum valve)......black/green upper thermal vacuum valve......and black/red (perge control valve bottom)
hope that helps., if you need more info just ask what part , thanks................:thumb:
