96 Talon Tsi awd turbo - tweeked
Yes that is the car. Yes it could use some clean-up and a few pretty hose covers to make it look nicer. It was not put togeather very well at all. In fact is was a dangerous vehicle in the condition I bought it. Missing bolts, twisted wire connections, really just a mess. The car now runs very strong. It is now on E85. There were so many issues I can't even list them all. I kind of like a challenge but this one was a lot of work. There is still more to this car than even I know. I believe the engine is built up but I don't have specifics. If I haven't blown it up yet it must be fairly robust.
Current know items
16G Turbo unknown source- probably ebay - it does have a serial number.
aluminium flywheel
6 puck clutch disk
solid center diff
HBC boost controller
blow off valve, now recirculated
K&N filter
3" full back exhaust
unknown throttle body - purple if it matters
Full FMIC setup
Large radiator with electric fan.
780CC injectors
SAFC air correction
255 fuel pump
A pillar gauges Boost - AFM - Voltage
in dash gauges work
New knock sensor
Elec windows work
Sun roof works
no cruise
no A/C
Heater Work
Ventilation fans work
New seal in transmission output shaft to transfer case.
Eclipse front and rear conversion.
