DeathdealerATX
- 170
- Oct 12, 2007
Monterey,
California
1g stuff (1990)
1g intake manifold - $40
1g black center consol -$40
1g cluster panel - $20
1g driverside headlight unit with motor $60
1g turbo cluster white face - $40
1g stock cams - $40
1g stock cam gears - $20
2g stuff (1995-1999)
2g Intake manifold - $40
2g egr valve - $10
2g awd starter - $40
2g stock sidemount intercooler - $40
2g awd turbo gas tank w/metal cover and mounting straps and bolts no sending units - $100
2g awd rear subframe, all suspension included - $250
2g lsd diff - make offer
2g awd driveshaft brackets - $40
2g turbo cruise control unit and lines -$40
2g turbo cross brace for front motor mount - $20
2g stock sway bar with end links -$20
2g bottom brace -$10
2g turbo crank pulley - $40
2g turbo power steering pulley on water pump - $10
2g driveside motor mount - $20
2g stock infinite amp - $20
2g turbo exhuast manifold - $40
2g Coil on plug setup - $100
2gb eclipse rear bumper -$40
2g Talon black hood -$40
2g manual front clothe gray seats - $80
2g rear gray leather seats - $40
2g power steering pump, lines, cooler, resovior - $60
2g front/rear crash support beams - $20 each
2g turbo manual eprom stock ecu - $160
2g 2 gauge piller pod black - $20
2g center consol (gray) - $20
2g stock shift knob (gray) - $40
2g non turbo manual ecu - $50
2g PSU - $40
2g GST 3'' extended for cat delete, small hole in flex pipe needs to be replaced make offer
2g stock o2 housing - $40
2g GST front axles - $80
2g stock cams - $40
2g stock cam gears - $20
Im parting out my 1998 awd turbo talon only a few things left lmk if you see anything you want...
more pictures at
http://s866.photobucket.com/user/jus...s for sale
1g stock cams - $40
2g egr valve - $10
2g PSU - $40
2g stock cams - $40
more pictures at
