Tuning Help in Rancho Cordova
mlctalon
Aug 16, 2009
rancho cordova, California
Hi,
I have a 95 Talon Tsi with 16g evo III turbo ported, 550 injectors, ARP Studs, K and n FILTER, and 3inch cat back exhaust. I have a SAFC Super on its way. Was wondering if anyone would be willing to help me tune. Im looking to run 20lbs of boost and mid 12s without blowing up :)
I have not dyno'd yet and not sure were I am as far as HP, but It spins when the boost hits also I am hitting fuel cut. I just want to do it reliable and with out the teeth killing fuel cut.
Thanks
:thumb:
unless your running higher than 110 octane 20 pounds wont do you any good if you want to get good power... stick to 16psi especially with the 550cc you got.... theres a shop in Vallejo who will tune it for abt 150 (street tune) KBR performance. you dont even need to have a wideband but just make sure your afc is hooked up already or they will charge more (80.00)
thats where im having my talon tuned...or if you want to do it your self you need a wideband and a logger.... also theres a shop near you called midnight performance but they are pricey
I could probably help you get a baseline but tuning for power without some kind of feedback device(wideband) isn't the best idea. If you are looking to run on our pisswater gas, I would highly reccomend at least a wideband before you crank it up over 12-15psi. You can PM me if you like, I'm just down the road and willing to help but I can't make any guarantees about safety.
