Last chance on the ZEX kit group buy!!
black_eclipse95
Apr 28, 2002
Myrtle Beach, South Carolina
Do you own a 1995 non-turbo 420A or a 1990 thru 1999 turbo or non-turbo 4G63 or
2000 thru 2002
eclipse? Well, I run a small car audio and performance shop in South Carolina
and I am trying
to add Zex to our performance lines. I need a total of 8 orders to do the buy-in
and I have 6 already. I only need two more people to get the line. The kit sales
for $600.00 plus shipping and am selling them for $450.00 and that includes the
shipping to you. If you would like to order, you can email me or you may call me
at the shop.
contact: Jan G. Lancaster
Precision Audio
2219 N. Main Street
Conway, SC. 29526
(843)488-3699 shop
(843)488-1412 fax
You can call in your
Visa, Mastercard, or American Express credit cards if you would like. Thanks Jan
THE KIT COMES WITH THE FOLLOWING THINGS:
Plug & Play Nitrous Performance:
All major components are contained in the ZEX™ "NMU", which means you won't have
any unsightly solenoids or wiring.
Worlds Only "Smart" Nitrous System:
Uses actual bottle pressure to regulate the nitrous to fuel ratio, always
optimizing the mix. Never too rich, never too lean!
Our nitrous kit only activates when you hit full throttle:
This means you can sit at the line with the system armed and your hands on the
steering wheel. When you hit full throttle, the nitrous automatically kicks in,
you don't have to fumble with switches and steering at the same time. When you
let off the throttle, the nitrous shuts off. Our difference in approach results
in more horsepower per nitrous used through all bottle pressures.
Zex Kits Include the following:
ZEX™ Nitrous Management Unit (Part #82007), U.S. Patent #5,967,099
The NMU is the brain of the nitrous kit. It hides the senosrs and solenoids to
keep your engine compartment looking good.
ZEX™ 15amp Power Arming Switch With Cover (Part #82002)
Protective cover prevents accidental system arming
High quality steel toggle switch allows many years of trouble-free service
Available assembled or as individual parts
Switch cover only - Part #NS6545
Switch only, no cover - Part #NS655
ZEX™ Nitrous Supply Bottle And Control Head (Part #82000)
Chrome bottle valve
Chrome bottle nut
10 lbs. purple nitrous bottle
-4AN Bottle valve fitting
Teflon bottle valve seal
Siphon tube
ZEX™ Nitrous Nozzle (Part #NS6550)
Precision CNC machined aircraft quality aluminum construction
Simple installation, screws into air intake tube behind mass air flow sensor
Three flow jet sets are included for your choice of 55hp, 65hp, or 75hp
Unique design provides perfect atomization of nitrous with intake air supply
ZEX™ Nitrous System Brackets, Hoses, & Hardware
Bottle brackets
Bracket, tall - (1)
Bracket, short - (1)
Nitrous delivery lines
-3AN stainless steel braided line, two feet long - (1)
-4AN stainless steel braided line, fifteen feet long - (1)
Vacuum hoses
Rubber hose, twenty-four inches long, 3/16 SAE30R/KY - (2)
3/16 inch hose clamps - (4)
Other hardware
Nozzle bulkhead fitting - (1)
Tap for cutting threads into the air intake - (1)
Wire taps - (2)
Barrel connector - (1)
Spade connector - (1)
Ring Terminal - (1)
Black cable ties - (10)
Grommets - (2)
Printed installation manual with pictures - (1)
All mounting screws, bolts, nuts
Why did you start a new thread on this when your original thread is only 2 posts down? And DSM'ers are afraid of nitrous anyway..
Regards,
