GoriLLa
- 39
- Sep 28, 2002
Who is Alsan and why do u all seek his advice?
its stock...
I would also skip the ARP main bolts and use stock mains because the ARP's are stretch bolts, and that certainly isn't an area where you want any stretch. Since you have spent this much on the motor, I would hate to see you run into crankwalk problems in the future. Since you are local, I would seriously suggest getting the 'Fix' performed on the block as a safety pre-caution. I'll touch more on that for you if you are interested. Also, make sure the block gets a fresh deck on it.
its stock...
