Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > General > Newbie Forum
Newbie Forum Beginner/newbie/general DSM questions. first mods, how to run 10's when you haven't run 12's yet, any tech question that doesn't fit in another tech forum. New Members must limit their tech posts to this section.
Reply
LinkBack Thread Tools
Old 12-06-2003, 04:49 PM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: jases91talon is an unknown
1G-specific Few ?'s about stock 1G Dsms
On the car description it says 195 hp. So i was wondering what boost that was set at.... When i got my car used it had the boost at 7. so is it 195 at 7 or 14 which i run now.... I also wondered what size fuel injectors are in the stock 1g talons (1991). Also, if i were putting in a big 16g turbo (eventually) in my car what size injectors are reccomended and what is the cheapest but most efficient Intercooler to put in? Thanks for any responces....
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Old 12-06-2003, 04:55 PM   #2 (permalink)
Proven Member
Reputation: chris26969 is an unknown
good question, I also wonder what PSI the t25 in the 2g is rated at. My car is at 210hp, but at what psi. ?
Offline
Old 12-06-2003, 06:04 PM   #3 (permalink)
Proven Member
Reputation: TheTSiGuy is an unknown
Well, most people who put REAL boost gauges in their cars have mentioned that factory boost is anywhere from 9-11. So it would be 195 hp, or 210 hp @ 9 or 11 PSI. its hard to say what your specific car does.
Stock injector Size is 440cc i believe.
If you plan on going to a 16g, and keep going with it, the popular path is to buy some 550cc injectors, a walbro 255 fuel pump, fuel pressure regulator (for 255's, 190's dont need one) and thats about it.
I currently have a HRC Super 16G, 550cc inj. and a walbro 255...which seems to be a common setup.
you could stick the 16g in if you want, and run low boost. otherwise, you're going to experience fuel cut and other nasty things, because your fuel system isnt dumping what the car wants. be careful.
Offline
Old 12-06-2003, 06:20 PM   #4 (permalink)
Proven Member
Reputation: CycloneAWD is an unknown
Stock fuel injectors are 450cc's...a 16G should run great with 550's a bigger pump...at least IMO a 190 LPH...3 Inch Exhaust System...and some sort of way to make...the ECU know you have 550's...and AFC or some sort of Piggy back or if you really wanna a stand alone...oh and a Datalogger...just so you know what you are doing you know??...
Just make sure you have some basics first...Intake Exhaust Aftermarket Boost Gauge and an EGT for the love of GOD get an EGT Gauge please??
Arif.
Offline
Old 12-06-2003, 06:28 PM   #5 (permalink)
Proven Member
EGT gauge..That would be engine temperature correct?
Why is this so highly needed? I've got the A/G gauge and boost gauge, and i thought that these were the 2 highly needed gauges. Never knew an aftermarket egt gauge was needed?
Offline
Old 12-06-2003, 06:30 PM   #6 (permalink)
Proven Member
Exhaust Gas Temperature?
wtf? explain its major significance please.
Offline
Old 12-06-2003, 07:02 PM   #7 (permalink)
Proven Member
You are right the boost gauge and an A/F meter are important...but with DSM's the A/F gauge isnt the most accurate way of telling exactly what is going on inside that 4G63 of yours...An EGT will accurately display your A/F Ratio and let you know if you are starving your motor, or running super rich...I have both the A/F and the EGT...There are lots of FAQ's and posts about EGT's in reference to DSM's...I think you should take a look and see what there is...I mean a $200 Gauge vs. a $5000 motor...
Offline
Old 12-08-2003, 11:07 PM   #8 (permalink)
Proven Member
Reputation: AWD92TalonTSi is an unknown
So you can tell when shit's about to hit the fan. usually around 1600-1700 deg F.
a pocket logger is another good engine minder. log knock counts and timing.
____________________________
Bryan
President-BroncoMotorsports
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.15491891 seconds (70.92% PHP - 29.08% MySQL) with 9 queries
