Sartuche24
- 123
- 1
- May 8, 2002
Somewhere,
Indiana
Ok this is the first time I've ever changed a timing belt. I feel that I can do it and I bought all the right tools to do the job I don't like to use Jerry Rigged tools. Well my question is this, I bought everything for the timing belt but the idler pulley, timing belt pulley, and oil pump. I didn't have the money to buy this and my car has 85,345 miles on the orignal belt. Now is it going to hurt to change everything but the oil pump and the idler and timing belt pulley. I plan on doing the oil pump in the near furter but I still have awesome oil pressure but I'm replacing the seals on it along with removing the balance shaft's also. What are the chances of the idler pulley and timing belt pulley giving out. I'll change them later when I do the oil pump but should I just wait and get the pulleys when I get the money or just change the belt now and worry about those later down the road. I feel that changing the belt is more important at the moment than anything else, and getting rid of the balance shaft's also. I notice most of the kits just come with the belts and tensioner so I'm figuring it shouldn't hurt anything by just changing the belt and shaft. Thanks in advance.
