| Newbie Forum Beginner/newbie/general DSM questions. first mods, how to run 10's when you haven't run 12's yet, any tech question that doesn't fit in another tech forum. New Members must limit their tech posts to this section. |
09-19-2003, 09:08 PM
#1 (permalink)
Proven Member
Oil Filter Clearence, Leaks, and Leaks. Help!
Offline
09-19-2003, 10:07 PM
#2 (permalink)
Proven Member
looks liek the cv boot is leaking
____________________________
92 LASER AWD.
Offline
09-20-2003, 11:20 PM
#3 (permalink)
Proven Member
Re: Oil Filter Clearence, Leaks, and Leaks. Help!
Quote:
Originally posted by xinfiniter
Ok, I have a question about my oil filter. Do you think I can get it off?? If not and I cut it, then is there a smaller one made that would fit our cars??
Measure the length of the filter and go to your local auto parts store. Compare your measurement to the various filters in the store there. I know that the Amsoil filter (but you won't find that one in an auto parts place) is shorter, but maybe some others are as well. You may also try a 1G filter-- it's bigger around (and will fit onto the oil filter housing) but may be shorter, I don't remember for sure.
J Doug
Offline
09-20-2003, 11:35 PM
#4 (permalink)
Proven Member
Region: SoCal
Oil filter clearence on big 3-inch exhausts
-Also check the cv boot for crack, there're some split boot that can be replace without removing the axel, but I have never try them.
-Kevin.
Offline
09-21-2003, 12:52 AM
#5 (permalink)
Proven Member
Ya, I saw them, but the sucky thing is that the clamp isn't split, so it needs to be removed anyways....
Offline
09-24-2003, 04:19 PM
#6 (permalink)
Proven Member
Ok, which type of axle seal should I use....I have a choice between Mitsubishi, National (O'reilly), and Napa brand. Anyone know if i should just stick with oem or is an axle oil seal an axle oil seal.
Offline
09-24-2003, 07:17 PM
#7 (permalink)
Moderator
It's usually good to stick with OEM when you can get it, but that seal's not holding back a lot. Whichever's closest.
Offline
09-24-2003, 09:41 PM
#8 (permalink)
Proven Member
Region: Rocky Mountain
fully built enjun
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
