ForcedInduction
- 46
- Aug 8, 2003
Londonderry, NH,
New Hampshire
Anyone ever timed themselfs on how fast it takes you to remove an engine? whats your best times?
. I could do just the transmission in under 15 min.That wasn't the question.i didnt rush on my engine removal.
. Just a cold evening, and an oxy-acetylene torch. Remove front and rear motor mount bolt, drivers side bolt, then torched the coolant hoses, slave cylinder line, driver side axle, and had a friend disconnect the harness while I was cutting. Just needed the motor so anything that was still attached was broken when the tractor lifted the motor out
