Greddy Turbo Timer install
z0n3x
50
Jun 20, 2003
Ok i installed my TT and everything is working, I have the pin-outs for the ECU on where to splice the wire. Im just not sure on how I should go about spliceing the wire? plug-n-play? Can i just stick it in a pinout? any help would be appreciated.
no no, I bought a harness and if you decide to use the speed sensor feature ( quarter mile etc..) You have to wire it in to the ECU no plug and play.
I just did this recently and what I did was to just take some of the insulation of that wire (splice) and hook the wire from the TT by splicing about half-inch and wrapping it tightly around it (kinda ghetto) then wrap it with electric tape. But you can also use those vampire crimps I think thats what its called and you should be Ok, mine works.
