TD04 or TD05H ?
bambam
Jun 13, 2003
:dsm: :confused:
TD04 or TD05H ?
Anyone know which turbo is stronger capable of more boost? I have 2 of each (family works for mitsu=free parts hehe) and dont know which one to use.
Also 1 of the TD05H's is much beefier and the output is much bigger, the identifying #'s have been machined off of this one could it be a 16G? how can i tell?
I have a picture to load to help but the forum isnt letting me will try again tomorrow.
thanks
obviously the td05H will out ou tmore...if you want to know what kind of turbo it is post a pic of the numbers stamped on the turbo and the comrpressor and Im sure Ill be able to tell you.
for some reason the site wont let me post the pic so here are the numbers :
TDO4 - S
49177-01900
TDO4 - S
49177-01900
TD05H - S
49178-01010
BIGGER TDO5H - NO NUMBERS ALL MACHINED OFF
this turbo has a bigger output and a machined chamfer. If you look inside the output of this one it has a dual set of fins unlike the other TDO5H. One set is a little deeper then the other and they look like two different sets closer together not equal distane apart like the other.
hope that is enough information i emailed dsmtuners to see why it wont let me post the pic
:dsm: :confused: :dsm:
So does anyone know if this is a 16G can you go any bigger with the stock housing ??
