Looking For Pics Of 2g Fwd 3" Exhaust
Hey is the car a turbo or a N/A. I actually just got done installing mine in my GS-T and i'd recomend going and taking it to your local garage. My bolts holding on my stock system were so rusted up and stripped that they needed to first cut off the bolt heads and next heat up the threaded piece w/ a huge torch till they could un screw it from my cat. Also, the Apexi N-1 ( what i got ) is a little different than the stock layout in that it goes under the subframe in the rear rather than over. Other than that, just follow your stock pattern and if you order the right exhaust all the hangers should line up.
