Solved my problem with the misfire
So many of you know I had a major misfire. Well, I replaced the injectors, coil, spark plugs and wires.Had it apart several times. But it was as simple as a weak fuel pump. so if you have a major misfire. Try to get a fuel pressure test. Mine had 27psi at the rail and put a new fuel pump in and it had a 50psi at the rail. So Simple fix I believe so
