Login
Go Back   DSMtuners > DSM Forums > General > Newbie Forum
Welcome to DSMtuners
Newbie Forum: Beginner/newbie/general DSM modification questions. First mods, how to run 10's when you haven't run 12's yet, any tech question that doesn't fit in another tech forum. Probationary Members must limit their tech posts to this forum and sub-forums.
Reply
LinkBack   Thread Tools
Old 06-21-2012, 05:45 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #1 (permalink)
smelygoatcheez's Avatar
Tech Posts: 3
Reputation: smelygoatcheez is an unknown
1G-specific
Firing problem on 91 tsi with 16 turbo
Awhile ago my oil filter came of wich resulted in the balance shafts getting stuck, which in turn snapped my timing belt i have done a balance shaft elimination and re-timed and replaced the timing. it ran for about 5 hrs then it lost fire to all cylinders i replaced a few fuses and the ecm now i have fire on 1 and 4 but not 2 & 3. Really want to get this running anyone know of any solutions any input would be helpful thanks. C.J.
mark post as helpful recommend reputation points    Reply With Quote
Old 06-21-2012, 06:50 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #2 (permalink)
Supporting VIP
Boost4U's Avatar
Tech Posts: 77
Classifieds Rating: 0
Reputation: Boost4U is an unknown
Run a compression test and see what the results are, I had a similar problem with my 1g. It was running fine then just stop running. I had 7 bent valves on the intake side and my timing belt was fine. I had a lifter stick up and push a couple valves into the pistons. I'm still not sure how so many got bent unless they were messed up before I got it. only one was hammered but the rest would wobble if I spun them in a drill. Also check for spark. A bad CAS can and will cause your coil pack to only fire on 1 and 4. that also happened to me just recently. Hope this helps or leads you in the right direction.
-Randy
____________________________
Randy Constable, 92 Laser AWD, 90 GSX, 91 GVR4 Auto swapped(1078/2k)
Old 06-21-2012, 07:00 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #3 (permalink)
Supporting Member
jpv91120's Avatar
Tech Posts: 42
Classifieds Rating: 4
Reputation: jpv91120 is an unknown
Well i think the coil pack on the left controls 1&4 and the one on the right does 2&3 so I would think the coil pack on the right is bad. You can check it with a ohm meter.
Old 06-21-2012, 07:20 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #4 (permalink)
Proven Member
MHuddy1213's Avatar
Tech Posts: 274
Photos: 8
Reputation: MHuddy1213 is an unknown
i believe the right is 2 and 3 also i would start there so you can start figuring it out
View photos of this member's car
Old 06-22-2012, 03:21 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #5 (permalink)
Proven Member
forcefed_90tsi's Avatar
Tech Posts: 31
Photos: 8
Classifieds Rating: 1
Reputation: forcefed_90tsi is an unknown
I agree. Start with that coil. And also the cas can cause a similar issue.
Old 06-22-2012, 05:25 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #6 (permalink)
Proven Member
GRAVEDIGGER's Avatar
Tech Posts: 2,189
Photos: 16
Reputation: GRAVEDIGGER is an experienced, knowledgeable member worth listening toGRAVEDIGGER is an experienced, knowledgeable member worth listening toGRAVEDIGGER is an experienced, knowledgeable member worth listening toGRAVEDIGGER is an experienced, knowledgeable member worth listening toGRAVEDIGGER is an experienced, knowledgeable member worth listening to
Might want to check the power transistor (aka ignitor). It gets an on/off signal from the ecu which in turn fires each coil seperately. You can have a loose/broken wire or just a bad power transistor.
How to test the power transistors
-Matt Graves-
soon to be HX40 powered....
Old 06-22-2012, 04:46 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #7 (permalink)
Tech Posts: 3
1G-specific
.ok ill check all those on sunday thanks for the help ill let you all know what i find out and does anyone know any good dsm info site im kinda new to dsm i have been a muscle car guy my whole life and just now getting into turbos and stuff love them. I want to figure certain terms and things out about my car like the 16 turbo i know the stock turbo is a 14b but have no clue what a 16 is out of. Just general knowledge would be extremely helpful thanks. C.J.
Old 06-22-2012, 09:28 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #8 (permalink)
Proven Member
MHuddy1213's Avatar
Tech Posts: 274
Photos: 8
this is the best dsm info site just ask any questions and well help you figure it out and do you have a small 16g or the evo3 big 16G there is a major difference
if you dont know get a picture or just write down the vin number on the turbo itself well let you know what you have any info about your car too will help us help you
Last edited by MHuddy1213; 06-22-2012 at 09:29 PM. Reason: Auto-merged with previous post to prevent "bumping" within a 24 hour period Tips on avoiding the auto-merge feature - http://www.dsmtuners.com/forums/faq.php?faq=vb_faq#faq_bumping
Old 06-24-2012, 01:40 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #9 (permalink)
Tech Posts: 3
okay so this is what i have found out the 16g i believe is the big 16G off the evo i remember the guy telling me that. The coil packs have been replaced about two weeks ago, which leads me to believe its the power transistor i have it out of the var im going to replace it and see ### it does thanx for all the help and if anything else turns up i will know where to go now. Oh and does anybody know any great tranny mechanics around the fresno, CA area my second went out just before the whole oil filter fiasco. C.J.
Old 07-14-2012, 06:57 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #10 (permalink)
Proven Member
snakeyes711's Avatar
Tech Posts: 604
Classifieds Rating: 6
Reputation: snakeyes711 is an unknown
Send a message via Yahoo to snakeyes711
Did this fix your problem?
Reply
Bookmarks
Thread Tools
» Recent DSM Videos
1gb AEM wastegate hood dump 2step
» Recent DSM Photo
Post your banner here
» Current Poll
How many times have you been to the Shootout?
1 - 38.41%
111 Votes
2-5 - 43.60%
126 Votes
6-10 - 10.73%
31 Votes
11-15 - 2.77%
8 Votes
16-20 - 4.50%
13 Votes
Total Votes: 289
You may not vote on this poll.
» Online Users: 923
330 members and 593 guests
Most users ever online was 1,704, 03-17-2008 at 09:11 PM.
DSMtuners Main Sections
DSM Forums
DSM Regional Forums
DSM Builds/Journals
DSM Articles
DSM Tech Guides
DSM Upgrade Paths
DSM Parts Reviews
DSM Vendor Reviews
DSM Classifieds
DSM Parts Guides
DSM Photos
DSM Videos
DSM Timeslips
DSM Dyno Sheets
Shirts & Apparel
DSMtuners Decals
Advertising Info
Our Sponsors
Site Rules
Terms of Service
Privacy Policy
Site FAQ
About Us
Contact Us
