Stock fuel injectors size? Stock size aftermarket injectors? (4G93 engine)
Rasul (Russia)
Sep 16, 2002
A friend of mine owns a 1992 Eclipse (4G93 engine). He wants to replace his injectors. What size are stock injectors for a 4G93 engine?
As I understand there is no need to install bigger injectors unless you are going to do further fuel mods (fuel pump, fuel management etc.)
Are there any aftermarket injectors available? The ones that have the same size but better pattern and other specs?
Thanks,
Rasul
its 4G63. is it a turbo? if not you do not need to replace them, pink injecters 240cc,blue,450cc,yellow 510cc. n/t just replace them with stock,
4G93 Twin Cam injectors STD =240cc Pink in colour on late models fitted in Proton Putra/M21 and Satria GTI
