Problem with my CAS
Originally posted by Sandman1182
I was wandering if a Cam Sensor from a 1G eclipse turbo will fit on a 2G 97?
The only time you use the 1st gen CAS is if you swap the 1st gen head on your full swap itself... There is no performance gains from using the 1st gen CAS... Just get a 2g one... there is not point of using the 1st gen..
There is nothing wrong with the cam sensor I have, I replaced my 95 engine with a 97 cause my 95 blew. and the connections for the sensors are diffrent. and i cant find the harness for the CAS and the 95 harness wont hook up to the 97. I just happen to have a 1G CAS and i was wandering if i could just replace the whole CAS because i have the harness for the 1G.
