3500 rpm idle 95 awd auto
95twinturboawd
240
Feb 26, 2009
jackson, Michigan
When we started the car the idle was fine but as we drove the car it became progressively worse. Then by the time we shut off the car it was up to 3500 rpm in park. The throttle body has been taken off and cleaned plus a new ISC
Inspect ALL vacuum lines and perform a boost leak test. Also a fiav that is failing will cause an abnormal idle.
  • For sale 2g 2g 1999 eclipse gs-t spyder
    Very clean 2g spyder, only modifications is 14b turbo with 3inch exhaust. Well maintained and...
    • DSM B
  • For sale 2g 1996 Talon TSI AWD
    1996 Talon TSI AWD $10,500- 90,421 miles ( will go up a little ) - clean title in hand -...
  • For sale 2g 2g power window motors. OEM
    RH and LH power window motors. OEM $40 each or $70 for the pair. Message 702-741-6987.
  • Wanted WTB 268 Camshafts & Zero Tick Lifters
    Looking to see if anyone has a set of 268 cams in drop-in condition. I know 268 is on the Rare...
    • Ice9
  • Wanted 2g Diff ring gear. Internal 98-99 Transmission
    98-99 Manual transmission front differential ring gear. MD770499
    • GIB
