rr06rs
Supporting Member
- 421
- 2
- Apr 25, 2009
Jacksonville,
Florida
I'm just curious what the max boost level is that people have safely seen? I'm replacing it and throwing in ARP's but the motor is staying in the car so the block won't be resurfaced. For the record, the gasket isn't blown, it's just a high mileage engine with some seapage and I'm just doing the basic maintenance on it while I put it back together so I already know it's not warped.
Also, if I were to have the head alone decked, would it be possible to use a MLS maybe with some copper spray on just the block side or would it be recommended to still use a composite? It's going to be a stock 6 bolt running about 35lb's max on a 6057.
