water injection with relocated battery
a95gsx
36
Apr 26, 2006
B'ham, Alabama
I picked up a used coolingmist water injection setup a few weeks ago and finally installed it. I mounted it where the battery used to go and it fits good with a minimal amount of wire and water line. A new nozzle and check valve from devil's own were plumbed into the pipe just after the intercooler. It's powered from the foglight relay as the lights got tossed when the IC went on. The relay is rewired to have power all the time from the battery which now lives in the spare tire well. Should the controller die from underhood heat I plan on getting a pressure switch. Just need to clean it up a bit now....
