AlphaAssault
- 480
- 1
- Sep 5, 2007
Tyler,
Texas
Trans has about 35k miles on the rebuild. A few weeks ago, i changed the trans fluid - my first time doing so since i bought the car 5k miles ago - and discovered there was only a quart or so of fluid in the trans. I changed it because shifting had become notchy after warm and at low rpms (shifted fine at higher rpms, i.e. >5000). when warm and at low rpms, the shifter would actually stop in the middle between first and second, and i would have to wait before it would let me into 2nd. i put in almost 3 quarts of penzoil syncromesh and the issue persists; its a little better, but not much. its been about 500 miles since i put in the syncromesh. still shifts fine at higher rpms.
im looking to swap in a different fluid, but am unsure of what to go with. syncromesh seems too thin, because its acting just like it was when there was only a quart of fluid in the trans; not to mention it shifts better when its could; i.e. before the fluid has thinned out much. Im not sure about a synthetic trans fluid, people say its pretty slick, even the higher weight gear oils. i was thinking about regular 75w90 gear oil because its cheap and thicker than whats currently in there, but i dont want to keep buying fluid, so this time around i would like to get the best stuff for the job. ideas?
