Slimfans
jayb903
99
4
Jul 19, 2007
Fayetteville, North Carolina
Ok all I really need is opinions. My cooling temps rise above 220F after driving for few minutes, and it causes knock. I just got a bigger turbo w/ ex. wastegate setup.:) I have a a 9" ebay crappy fan. B/c of the wastegate positioning.
Now I just want to know if I should just get a new radiator or a new slimline fan or both. And how cool you got you temps.
Thanks peoples:thumb:
You can't even run the stock passenger side fan? Do you have dsmlink set to run the fan all the time? How fresh is your coolant and what is the mixture ratio?
Also, do you have a heat shield on the manifold or turbo?
Get a 14 inch fan. Problem solved. At first I thought my setup would kill my car and make it overheat. It's actually not that bad. My 14 inch fan is sufficient enough for it. I had to eliminate my 12 inch fan due to the WG as well. My turbo is not heatshielded. It's only Swain Tech coated. If you're still overheating, the problem may lie elsewhere. Do a check on your coolant with the multimeter.
Yes I do have Dsmlink, and I am using the passenger side fan. I haven't put my heat shield back on yet. I will try and get a 14" fan. Thanks.
FWIW, I only have my passenger side fan and I have never seen my temp go above 203. This is with the fan set to always on.
I'm only running the stock passenger fan and it does the job, i got no a/c condenser tho although i have a huge fmic.
I also run a 160 degree thermostat, car runs way too cool in the winter tho, i offset it in dsmlink so that the ecu doesn't stay in fuel enrichment mode.
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
  • Wanted 4G63 800cc injectors
    • DSM_Thorpe
