no acceleration
413NEP
Aug 14, 2008
Spfld, Massachusetts
Hey guy i need help. I have a 95 gst with 16g, new 02housing with external dump 3inch down pipe and full cat back. Also 2.5 inch air intake. I have just installed all theis parts and bam. The car is so slow no boost at all. After doing a boost leak test i unpluged the MAF and then the car started to boost but not much any info would help alot.
i am talking about no boost at alll the car feels like it is N/A. the only acceleration i have is when the MAF is unpluged.
ok the problem stated when i put the 2.5inch intak and had to fab it to the MAF. Well i am going to put the stock one on and see were i am . Leak test good no leaks. I checked spark fuel timeing. No DTC's for maf. thanks guys mabe this will be it.
well i used a 2inch cupler and a peace of pvc and drilled a hole in the middle.Then added a air pressure gauge i clampt it down to the turbo inlet and hooked the compresser to it. Also found out what the problem was AITS.
