Kalisko
- 267
- Mar 19, 2008
Lawrenceburg,
Indiana
1g Motor, 6bolt.
Hey guys. I was looking at my eclipse today, when I noticed my exhaust hanger was broken off (the rear most hanger) so It was grinding the ground and making the car run funky. So, I crawl under the car to look at it. I put it on a jack stand to raise it back up, and voi'la. Problem solved.
THEN.
I turned the car off, went to pull the jack out from under the exhaust, to find oil dripping.
I tried this again, I cleaned up the oil, and turned the car on. No oil leaking. Turned the car off, looked back down there, and it's dripping
What could cause this? It's coming from above my transfer case, because it's dripping down from above it, and running down the transfer case.
THEN.
.What could cause this? It's coming from above my transfer case, because it's dripping down from above it, and running down the transfer case.
