costas14
- 489
- Mar 7, 2008
quincy,
Massachusetts
so fixed up the 95 gsx a bit, hooked up coolant lines to the intake, put a thermostat in but i notcied lots of white stuff when i opened it up, like lots of chunk, no oil, i fixed the oil leak on the bottom of the oil pump, the fan comes on so it doesnt overheat, but the radiator hose is hot and lots of pressure, turbo noise is weird, it holds boost perfect, its running 10 i floored it in the parking lot here at the shop and it blew off perfect no stuttering or anything, but like i said lots of white stuff from opening up to put a thermostat in since there wasnt any, and the turbo sounds weird, and theres no water lines going to it, since the water pipe on the block doesnt have the nibbles to connect to the turbo, oil is still clean, waiting to put synethetic in but i dont want a blown turbo, so i have to figure out what this white crap is
