Jets303
- 98
- Aug 24, 2008
lakewood,
Colorado
Im looking for a fast street car/ daily driver. I want to make 300hp asap and i need to know what turbo setup works best. I know this question has been askedd 100 times but i want someone who really knows what they are doing to help me out. The lower end of my motor is setup to handle well over 300hp so im not worried about that. I spent so much time and research on the mototr itself and i want the same for the turbo. Thinking about the 20g with bigger IC and a dsm link?
Lower End:
-J.E. Pistons
-Scat H-Beam Rods
-CP Gas Nitrated Piston Rings
-King Performance Bearings
-Modified Thrust .395 Wide
-Entire Block was Balanced and Blueprinted
-Performance 3G Lifters (no lifter tick)
-The Balance Shafts Removed
-All other components used in rebuild are brand new O.E.M. parts.
Head:
-Crower Stage 1 Street Cams
-Cometic Steel Head Gasket
-ARP Head Studs
Transmission:
-Act 2100 Clutch
-Fidanza Aluminum Flywheel
Fuel:
-Walbro 255 lph Hi-Flow Fuel Pump (High Pressure) (not installed)
-Fuel Pump Rewire Kit (not installed)
Exhaust:
-Turbonetics External Wastegate
-Custom O2 Housing
General Engine:
-Aluminum Air Intake
-Upper Intercooler Pipes
-Greddy Type-S Blow Off Valve
-K&N Filter
Electrical:
-Greddy Profec B Boost Controller
-Greddy Turbo Timer
Suspension:
-Front and Rear Strut Bars
Drivetrain:
-New Hub Assembly on all four wheels
-New Rear Differential (all work done during engine rebuild)
Lower End:
-J.E. Pistons
-Scat H-Beam Rods
Head:
-ARP Head Studs
Transmission:
-Act 2100 Clutch
Fuel:
Exhaust:
-Custom O2 Housing
General Engine:
-K&N Filter
Electrical:
-Greddy Turbo Timer
Suspension:
Drivetrain:
About how much boost do you think i can run?
