Srt4RacerDave
- 193
- Aug 9, 2008
Strongsville,
Ohio
Still attempting to fix my idle surge and I need some solutions. I cleaned out the throttle body. About 50 minutes ago, I replaced the idle air control valve/sensor. It seemed different, but it was still surging. Someone told me it could take for up to a week for the ECU to recognize the new valve and idle normally? It idles between 1100-1250 RPMS. When I first put the valve in, I'd pull up to a light and it would surge twice and then idle normally. Then, after driving it for a bit, it started to surge again. Could it be fixed, just not driven enough yet? Also, if anyone has any other suggestions on how to fix this, I'd appreciate it. I heard if one of the duel injectors was clogged or something, it would cause this. So I checked the spark plugs and they were all the same color, so I dont think that's the case.
