pei-tsi
- Nov 12, 2007
cardigan,
my car developed a oil leak slowly, i could smell it every now and then for a day or two and i checked but there was no visable leaks ,but yesterday it started flowing good, nothing at idle but as soon as i put stress on the motor(taking off) it would start leaking almost a steady stream, its up on jack stands now and its wet everywhere so it was hard to trace the general area, but it was coming from behind the turbo and it looked like it was one of the steel lines back there, now after removing the manifold to get a better look i found that all those lines are coolant lines(correct?) the turbo oil lines are fine and the turbo itself is dry, there is one banjo bolt going into the block behind the turbo with a line going to the filler cap housing and the leak seems to be comming from the banjo bolt area but that is a coolant line so am i missing something? i love my car but at this moment i'd love to see it burning
i had it idleing on jack stands and no leak even reving it, i rode the clutch with my foot on the brake and it would leak from the front of the motor just below that large coolant line
