dustin_8907
- 83
- May 7, 2008
Ripley,
West Virginia
Just wanting to know what this is and the benefits of running this. Thanks
This is removing the stock mass air flow sensor (located in front of the turbo) and lets you use a GM mass air flow sensor in it's place (located between the throttle body and blow off valve). Doing so requires you to purchase a maf translator box (usually priced around $100 or so) and it's fairly simple to wire in.
Lol who you kidding? I wish it cost $100. The most simplest MAFT cost $200 from extremepsi.com The MAFT2 cost $260 and the Pro cost $400.
Well, it should, that's the only way you could get the BOV to work properly without having your motor idle badly.
