Stuck on dash removal, almost out but need help
truwarrior
1,422
6
Dec 19, 2002
I removed the gauge cluster but there appears to be 2 yellow clips and a clear clip holding three harnesses in place. Are these suppose to come out or do the wire harnesses just get disconnect some where else? If they are suppose to come out, how do you remove them. I can't seem to figure it out and don't want to break them :coy:
Thank you in advance!
Please don't mind the other wireing mess for my boost and pyro and a/f controller on the column LOL
Ah ok, so they're not suppose to be removed from the the dash? It looks like they can be but not sure. I'll see if I can trace the wires. I still have to finish removing the steering wheel. Any other recommendations in the meantime is appreciated as well!
Thanks again!
There is a plug that plugs that into the rest of the body harness. If I were at home I would take a picture for you. But yes that all comes out with the dash as one unit. Then you can simply unplug it from the rest of the harness.
