deputy865
- 177
- Sep 17, 2007
Fenton,
Michigan
I have a little dilema. During a boost leak test i found a leak coming from my BISS screw. Now, i searched and read that if you are set at your desired idle, to just put silicone over it and it wont ever leak again. But here is the problem, i would do that but my car idle's very oddly upon starting. The idle goes up, then down, up a little less, down a little less, up a little less, down a little less then settles. Sometimes i have to give it gas right when i start the car or when the idle goes down, it stalls itself out.
So can i just mess around the BISS and fix that or what? And is adjusting the BISS just as easy as screwing it in or out? Or is it not that easy?
Thanks,
Shane
Thanks,
Shane
