dennyt4
- 136
- 2
- Feb 18, 2008
Kannapolis,
North Carolina
OK I seem to be having an issue installing the Megan AWD cat-back on my 98 GSX. I bought it used from a fellow member, but everything looks exactly as it does in every picture from all the vendors and nothing looks altered at all. I've also installed several cat-backs on my previous Evos and other cars with this much trouble so I need some help please.
Below is a stock picture of the exhaust with the hanger circled in red that seems to be causing the trouble. As soon as I hang this in the rubber hanger, it throws the alignment of the midpipe completely out of wack and pushes it way over under the driveshaft. If I leave it out of the hanger, it lines up with the axle-back and with the small section that has the 2 hangers by the rear O2, but I'm afraid it will just not have enough support for the weight and sag or cause an exhaust leak.
What does anyone else do with this? Thanks for the help!!!
