Boost Controller
konvicTTalon
Jul 5, 2008
point pleasant, West Virginia
im wanting to hook up a boost controller what do i need to do this...do i have to change my wastegate or what??...also and edit i only wanna get or around between 15 and 20 pounds
No you dont need to change your wastegate.
Depending how much boost you want to run you may have to do other mods as well.
My thinking is that you should do a bit more reading about your car before you go trying to up the boost to the sky. These engines are stout, but if you run ANY engine too lean (like say from upping the boost too high and not having anything else for the fuel supply) it WILL blow. My suggestion is that you can run a manual boost controller but please don't go crazy with it. You will knock more then a door to door sales man if you go too high.
