92 2.0 turbo timing
cams look good, get the rest of it on then spin it over a few time by hand and make sure you can still make them line up, may take a few turns to fully line back up
yes...turn the a crank about 8 time...and recheck all timing mark. Make sure the balance shaft is in the correct phase. Easy to do, just remove the bolt that is behind the block (where the balance shaft) and stick a screw driver in it. if it goes all the way threw, then your good. Make sure the engine is at TDC when you do it.
