6 bolt wont rev/idle for crap.
dc90ms
97
Nov 1, 2006
harrisburg, Pennsylvania
today i tryed checking the timing in it and i completly re did it and it good now. so went to start the car and it cranks fires then dies. some times it would start normaly go up to 1500 rpms and let go of the key and it dies. it just dosent want to start. if i pump the gas pedel and crank it it would start and run if i pump it. if i try to hold it it would die. if i floor it it was die. i dont no what it is and about to give up on it. i was working on it for 3 months now???? i put a 3 in turbo back exhuast on it and new 02 sensor. the tps is aligned timing is good but it might not be i dont no LOL cas is good everything looks to be good. i had it hooked up to a comptuer and all the sensor are working. but the fuel pump dosnt true on when i turn the key on it only starts when i start cranking and if its the car is running it will stay on but when it the car dies it turns off i dont no if thats normal or not.:beatentodeath:
well i did the swap n it was doing the same thing so i give up on everything esle and tryed my luck with the timing and re did it so it good now for sure did it 4 times to be safe LOL and noting
Start a new thread. This one was never clearly defined so your issue should be looked at by itself. You'll need to explain in the new thread the details currently and what lead to the current problem. Make sure you have a current profile on your account.
