6 bolt in a 98GSX but which DSM LINK do I get?
Ok thanks guys!! and my 98 transmission will work fine with the 6 bolt right?
Auto or 5 spd? If it is auto, you are better off getting the kiggly kit.
As for the link, get it for you specs with "invert cas" as a default.
As for getting the version that matches your ecu, there is only 1 for the 2g. That matches the also required 95 eprom ecu.
Well since you have a 5 speed, don't forget you need a 6 bolt flywheel. Either FWD or AWD whichever you need. And they are not interchangeable.
AMEN!!! Only because I learned that one the hard way. The awd is smaller which in turn doesn't catch on the starter when you try to start the car. Talk about a pita!:coy:
