line running help please asap!!
BoostinGSX17
50
Mar 22, 2007
Sicklerville, New Jersey
I have a 1g motor with a 2g head and i have a big 16g turbo that has internal wastegate. THe first problem is that the BOV looking wastegate thing that i bolted on the side of the turbo theres a little valve for liek an airline but i have no idea where it goes sorry no pics. Another one is i have the 2g MAF and underneath in the front there are 2 lines the one on the right looking from the front bumper going to the valve cover and the one to the left is the one i cant find where it goes. Any help would be greatly appreciated.
the nipple that is coming off of the wastegate should be hooked up to a vaccuum line, the closer to the turbo the better. also if you have a manual boost controler, this is where that should be hooked up to.
im assuming youre using the stock 1g j pipe. if so there is a nipple on there. run a line from that nipple directly to the nipple on the wastegate.
then youll have to put one in yourself. there are several ways to do that. the easiet that ive read is to buy a nipple and drill a hole in the pipe and just use jb weld to hold it in. there are other methods which you can find by searching for. im at school right now so i dont really have the time to search for you haha sorry.
thanks but i still cant find where the MAF tube goes it seems like a pretty big nipple that it fits on because of hte hole in teh plug.
