SliderX
- Apr 1, 2008
Chicago,
Illinois
I read through the FAQs and searched through the forums but didn't find anything on this.
It's a 92 Talon AWD 4bolt rear. The owner says he recently put in an ACT clutch 2600, he changed the slave and didn't change the master cylinder. He says it's hard to get into 5th and you have to kind of pull it towards you and then put it in. It was fine before the clutch change. He says it's just the master cylinder, and it's a problem with DSMs and they have trouble getting into the right gears if the master cylinder is going bad.
Is this true? Or am I looking at bigger problems?
Thanks for the help,
Mike
Mike
How does 5th feel when its engaged?
