300hpbound
- 91
- Mar 20, 2008
Westminster,
Colorado
I know this is something that comes up a lot, but I hope that You all can help me a little.
If I come to a hard stop, it almost dies, then comes back up a floats around a little, then goes back to normal.
I read through the whole "Terry's Talon Troubleshooting" about 10 times.I have cleaned the Throttle Body and the EGR valve. I have checked the ISC, all four coils reading 32 Ohms (at cold).As far as I know, the O2 is fine, otherwise it would throw a check engine light (correct?). I've also checked all vacuum lines and haven't found anything. I was told that it could be the Idle Air Control Valve. could one of ya'll point it out to me, ### I can't find the damn thing. Or should I just replace the throttle body suspecting its the FIAV?
It's an auto 93 Talon Es
I checked around the other similar threads and none of them have the same info and problem
