rob1621
- 387
- Jan 4, 2007
Wisconsin Dells,
Wisconsin
hey guys i haD A question i have posted previous threads and you guys have helped alot and thanks for the help.but i was wondering if anyone knew if the timming marks on the cam shaft sprokets HAD TO BE ALL ALIGNED straight. when my two timming marks in the middle of the cam shafts are line up the outer ones are not i am able to turn the cams without having the valves hit the pistons if the outside ones are not aligned the valves dont hit the piston. so the final question is do they all four need to be aligned straight thanks for the help
