kergilman
- 207
- 1
- Oct 25, 2007
Portland,
Oregon
I finally decide upon and purchased a WB kit for my 420a. I bought the Zt-2 w/ LCD display & MAS sensor. I did a lot of reading on the archive of W/B discussion, but still have a few questions before installation.
1) I see some people leave the WB O2 installed while others remove it and plug the bung after they are finished tuning, what are the real benefits here either way...?
2) Most Mfgrs (including Zietronics) recommend installation of the bung at either 10 or 2 O'Clock position on the pipe and at least 16-18 inches from the valves or turbo outlet. They warn not to use the stock bung for heat reasons (mine is about 17" from turbo outlet). I can weld on a new bung w/o an issue...how far down the pipe is optimal...?
3) The Bosch harness is pretty thick. I have run out of room in the firewall hole I tapped just above the top of the brake peddle mount. Looking for a harness hole I can share to avoid drilling another hole.
Also, the LCD is a little larger then I expected. Looking for a good spot, I had problems deciding. Finally I think I will make a bracket that mounts to the sunroof control panel on the ceiling. I'll post pics if it works out...
Thanks in advace for any advice for my 420a specific installation...
