camber (what kit is neccessary) question
aeveret2
Jan 5, 2007
toledo, Ohio
I tried that one the backs work good, they are just shims to move the upper control out. Those front bushings didn't fit and aren't even adjustable. I wouldn't reccomend that kit. I would just make your own rear kit with spacers and longer bolts. Then buy a good ingalls kit for the front. Its not worth trying to go cheap on this TRUST ME.
Why wouldn't they adjust for you? They're identical to the SPC Eccentric Bushings and, in my opinion, the best camber setup you can have in the front. No worry of hitting control arms etc like with anything Ingalls or that has an adjustable ball joint.
fantastic, I think I'll give these a try, and perhaps update this thread when the parts are installed.
hey guys i bought an ebay kit that came with spacers for rear and the essentric bushings for the front.. i pressed one of my stock bushings out to press the new bushing in.. it wasnt even the correct size....:mad: so i just spaced the rear which was cool.. but still pissed at the front.. but it seams better the the moveable ball joint type i just dont know where to get a good quality one for the front.. which will actually fit
Did your eccentric bushings arrive in an SPC box? Or are they truly unmarked? I bought ebay brand stuff and I was shipped SPC parts, thankfully.
I use the SPC forged control arms myself, so I never had a chance to use the SPC bushings...though if they could be installed together...
Anyways, maybe take the arms and the bushings to a shop and see what they can make of it? I don;t see why they wouldn't fit if they're supposed to.
