Squeeling from front brake pad?
imagine3163
179
Aug 2, 2006
Newberg, Oregon
Hey guys, I have read most of the threads I could find about this squealing noise coming from the wheel well and I think I have it narrowed down to the brake pad. Basically, the car has a high pitch, non-constant squealing noise that happens whether I am turning or not; accelerating or decelerating; and even in neutral when I am moving. From what I have read, when the brake pads wear down they have a squealing mechanism. My question is will this squealing only happen when the brakes are applied or should it squeal all the time if the pads are wearing down? Thanks
Pop off the wheel and check the brake pads. It's easy enough and it will keep people from telling you to check your brakes. No need for us to keep coming up with far strung ideas if your pads are worn. If you have a jack, it might take you all of 15 min to check.
