xxShaneOmac
- 423
- Jan 2, 2007
Everett,
Washington
Whats Sensors / Variables are affected pre / post closed loop.
Open loop - Car is cold extra gas?
Closed loop - Car has reached op temp less gass?
What sensors either start or stop working at this point?
I.e FAIV closes once you reach op temp (?) etc.
I have a horrible Gas / Air / maulfunctioning sensor probelm once I reach closed loop
(Im assuming its closed loop, once the car is at operating tempature)
o2 Sensor? TPS ISC MAF FAIV EGR FPS FPR Injectors Gas pump??
IF, how are these affected and may cause a shortage of air / fuel?
At Op temp my idle Drops and chokes the car then bounces back to normal (never above normal idle rpm)
<5% throttle at results in harsh bucking at op temp.
Help thanks!
Help thanks!
